on 23-12-2023 05:42 PM
Hi
Im trying to view my local IP cameras using a Huawei H112-370 router with three simcard on my iphone using the IVMS-4500 app but they wont connect.
As soon as im on a external network they work fine using a DDNS server, can anyone help please?
on 23-12-2023 05:54 PM
I can view the cameras fine on my DVR on the same network, just not on my iphone using IVMS-4500 app
on 23-12-2023 06:52 PM
Hey.
Ah, that sounds like a frustrating issue to be having. Have you changed any of the settings of the 4G/5G Hub?
What happens when you try to connect via the app when you're not on the local network?
on 24-12-2023 03:49 PM
Hi
No i have not changed any settings just set the DDNS and port forwarding up, if im not on the local network the app works fine and i can view the cameras.
on 30-12-2023 06:28 PM
I'm not sure I've understood correctly. To confirm, when you're connected to the local network (through WiFi I'd assume), the connection won't work. But once you connect externally (through another wireless network or mobile internet connection), the connection to the cameras will not work?
If I've not understood this right, could you confirm a more detailed layout of the network and connection types/devices you are using?
