Midi 4g not connecting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on โ02-05-2024 12:28 AM
Is there a reason my mifi is not connecting wirelessly to my laptop? The modem is not even showing up under the connections. I can only connect via usb to get a connection.
- Labels:
Coverage
on โ02-05-2024 07:06 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Check the settings to ensure your network isnโt set to hidden. Iโd bet a pint on that being the issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
โ02-05-2024 08:37 AM - edited โ02-05-2024 08:43 AM
If you try to connect to a hidden wireless network then I believe you have to manually input the name (SSID) of the wireless network that your mifi device is using. Failing that log into your mifi device settings page and unhide your wireless network. Alternatively reset your mifi device and start again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on โ02-05-2024 08:29 AM
So when I go to settings I have noticed a hidden network. What do I do with this mate? I appreciate your help ๐๐๐
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on โ02-05-2024 08:38 AM
There should be an option to reveal the network by unticking a box. But Iโve done this myself before and trust me the best way is to reset your mifi. Do this by removing the back cover and somewhere along the edge is a small black button. Get a pin or needle or opened paperclip and hold the button down for around twenty seconds (Youโll hear it click). The lights on the router will then flash for around a minute or so whilst it reconfigures and reconnects. Now refer to the white label and look for the network name and go to whatever device youโre trying to connect and it should find that network. Youโll have to connect using the default password (also on that label) and once connected you can either rename the network and change the password,or leave things as they are.
Do all that and youโll be sorted.
