Mobile data network
Steveo4813
Mobile data has not been working for two days now ?. Is anyone else experiencing problems?
1 REPLY 1
Hi @Steveo4813,
Sorry to hear you've been having issues with your mobile data. I'm not aware of any widespread issue at the moment, but you can check for any local issues on our Network Status Checker. I'd also recommend to check our Device Support page. From there, find your model of phone, then use the options in the "fix a problem" tab to find relevant troubleshooting.
Please let us know how you get on with this.
