NR5103EV2 External Antenna?
m1
hi i recently got a NR5103EV2 three 5g hub in the last month or so, in a bit of a pothole with coverage, quite unstable with the signal even through fibre, hence resulting to this device instead, need some thoughts on some external antennas and the ones with the right connections seems to be there is barely any information on what type of connectors they are if they are ts9 or ANT connectors, its not very defined.
need to get one that will be compatible with the router, and atleast in the 7dbi to 10dbi range
2 REPLIES 2
HandymanDom
Hi, I had the same problem finding information. I have just purchased a 5g antenna on eBay at the following link: https://www.ebay.co.uk/itm/174683071810?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=klz1AgfsQ1S&s...
I used 2 x sma to TS9 adaptors and purchased the mounting bracket.
I had very poor signal and intermittent connectivity, but so far so good after installing this small and cheap antenna.
Sargonuspa
I would like to know this as well.
Type a product name
