on 01-05-2025 09:46 PM
on 06-05-2025 08:54 PM
Try toggling airplane mode on for about 10 seconds, and then back off
on 02-05-2025 09:32 AM
Hey, Barry.
That's not so great.
Did you try restarting the phone already? If you're still having issues, it might be worth having a look at the service status to see if there's anything going on that might explain the issues you're having.
on 02-05-2025 09:00 AM
Most likely an outage if your signal is usually ok. Check the Three status page for more info.
