on 17-04-2024 10:50 AM
Hi was just wondering if anyone could help? Travelling to USA in a couple of weeks? What is the best roaming plan? I spoke to someone at three the told me the 14day pass for £24 would be good but when I read it, it’s doesn’t say USA on it so am confused? Will that pass work? As on the more infor bit it’s states all 49 places and USA isn’t on there.
on 17-04-2024 12:11 PM
Hi @Emiloub,
The 14 day pass you've mentioned is Go Roam in Europe, you should also be able to find Go Roam Around The World passes too. Those are the ones that will cover you for roaming in the USA. If you log in to your account on the Three App, then go to the Add-ons tab you should see "14 Day Go Roam Pass - ATW & EU"
You've actually posted with great timing though. Check out Ready to Roam this summer – Giveaway and tell us a bit more about your experience there. You could be in with a chance to win some Roaming passes, by simply giving us feedback about this very topic!
