on 12-06-2025 03:02 PM
Hi
i depend on WiFi calling as we have no signal. It worked fine, I went on holiday p, used an eSIM and since I came back a week ago, it hasn’t worked.
ive switched phone off and on, switched off WiFi calling and back on, can’t find VoLTE as mentioned in some posts. Phoned Three but they said it’s nothing to do with them.
It’s a iPhone 14.
any help?
thanks
12-06-2025 03:20 PM - edited 12-06-2025 03:22 PM
There was an issue with a carrier update which has now been resolved. If you go into the settings menu general/about then scroll down to network provider and it should say Three 64.2. If it says Three 64.1 simply tap it and it should offer you an update. Accept the update and that will then solve your problem.
on 23-10-2025 06:07 AM
Hi there,
I am having the same issue as above - calls going straight to voicemail when I am at home and Wi-Fi connected. Have poor reception at home so rely on Wi-Fi but missing important calls.
I actually bought a new phone as I thought the issue was with my old phone but the issue has persisted.
I checked as instructed above and actually have ‘three 65.0’ listed as my network provider. Any suggestions? Have also called three and gone through all of the suggestions they made to no avail. Interestingly they didn’t mention the solution suggested here which seems to have worked for some.
would appreciate any advice, thanks!
on 24-10-2025 10:32 PM
I have this same issue too. What area are u in? I’m in tower hamlets and my post code shows a service outage in my area on their network coverage checker. Three customer support said it’s an ongoing issue they’ve had for a while, they told me they’d update me but never did surprise surprise.
on 24-10-2025 10:33 AM
Does the issue happen on all Wifi networks? Which Wifi provider are you using?
on 04-08-2025 05:57 PM
I am using iphone13 and IOS 18.5 but recently i keep having issue with receiving incoming calls / outgoing calls with wifi call, is that a norm?
on 05-08-2025 12:18 PM
Hi @monjibza,
Sorry to hear this, so just to clarify calls are working fine when you have 4G/5G signal showing, but if you're on Wi-Fi calling what happens? Do the calls fail to connect, are you receiving call notifications, or can you explain a little more?
There was a Wi-Fi calling issue a few weeks ago, did you check out @Paddiewack's advice below to make sure your carrier settings have updated?
on 04-08-2025 05:55 PM
I recently have issue wifi calls, i am using iphone 13 and ios 18.5 but seems hardly can take incoming call or dial outgoing call
17-03-2026 11:41 AM - edited 17-03-2026 11:42 AM
When I try this on my Galaxy A55, I've only got, settings>about>software information>service provider software information & it doesn't say anything about three or any other network for that matter, not does it have 64 or numbers close to that.
When I was on O2 with this phone my WiFi calling worked, since moving to three yesterday it doesn't work. Could it possibly take a while for the carrier settings to update?
on 17-03-2026 12:54 PM
I had an old iphone and, as other members seem to agree, the problem coincided with the switch-off of 3G. Paddiewack's suggestion did not work for me or other members. I depend on Wi-Fi calling so in January I bought a Galaxy A17 and it's worked. When I go into Settings - About phone - Network, it just has 3 and nothing else. Tapping this doesn't change anything. I assume that you've been into "Software update". Good luck
