on 23-04-2024 09:28 PM
I want to know if i had to use my three sim for next month upon completion of my current one month pack , which data pack or data addon is to be top up so i would be able to get data for next month
23-04-2024 09:47 PM - edited 23-04-2024 10:07 PM
A data pack is your monthly data allowance which you buy with your top up. A data add on is what you’d buy at extra cost if your monthly allowance runs out to see you through until you apply your monthly top up again. It’s probably best to buy a larger data pack with your monthly top up than you think you might need,that way it works out cheaper.
on 24-04-2024 02:24 PM
Spot on @Anonymous. Data Packs include calls and texts as well as the data, and a data add on, is something you can "add on" if your data pack allowance has ran out before the pack expires.
on 24-04-2024 02:25 PM
Thanks! Glad I’m pay monthly.
