on 21-07-2022 02:30 PM
on 22-07-2022 02:16 PM
Hi SaidE,
Our routers automatically configure their APN settings, so you wouldn't normally need to enter in anything manually. Can you confirm what model of router you are using, and whether you purchased it directly from Three or a 3rd party?
on 26-07-2022 02:42 PM
Hello
Is Huawei 5g hub I bought from 3rd party
26-07-2022 03:22 PM - edited 26-07-2022 04:31 PM
Hi SaidE,
Thanks for confirming this. As I mentioned, usually your router would configure this automatically. If your device isn't doing so, enter 3internet as the APN. Usually you would leave any other fields in the APN profile empty.
Let me know if this helps.
