on 15-10-2025 05:18 PM
So its all wired up correctly
Ive got the app ive been through set up 10 times
And all it does is say
Create wifi network(in red)
We found a issue
Check to see if you eero and modem are connected properly then try again
Well they are !!!!
What do i do
Help!
on 15-10-2025 10:14 PM
Check the eeo log for any relevant error messages (activity page, clock icon at top right)
Try connecting a computer directly to external hub via an ethernet cable and check whether you have an internet connection and can the web and access the hub settings page.
