on
12-11-2022
02:04 PM
- last edited on
12-11-2022
06:30 PM
by
I have a mobile broadband data SIM. My number is ***********. I am trying to create a my3 account to check my balance buy I am unable to create an account. How do I check my balance?
on 13-07-2023 02:28 PM
I do not use VPN or any other proxy. I tried plugging in the sim to another device, did not work again.
Getting same message I mentioned before.
on 14-07-2023 11:25 AM
Hmm that's very odd. I actually registered a data SIM personally yesterday so it doesn't seem to be a universal issue.
Do you get the same issue when trying to register on three.co.uk with a browser and from the Three App?
on 14-07-2023 09:17 PM
Only on the website, not app.
I also receive SMS and work as a normal sim but can not register and top up.
on 17-07-2023 05:17 PM
Ah I see, so this is a PAYG account? Based on what we've tried so far, it may be worth trying alternative browsers, and alternative devices if possible next.
If that still returns the same errors, have you tried chatting with us?
I'm not sure if there's much more troubleshooting we can try from the community, so I think the next steps will be for them to attempt to reset your online account, and if that fails they should be able to raise the issue for further investigation.
on 12-07-2023 11:53 AM
I am having a problem in registering. It is saying:
You need to be connected to your Three Home Broadband hub or mobile device to register. Please connect and try again.
on 13-07-2023 12:19 PM
Hi @azerirehat,
Is this for a Home Broadband hub, or a Mobile Broadband like a MiFi or Tablet/iPad?
If you're using a VPN you may need to disconnect from this whilst you initially register.
Likewise if you're using an iPhone or iPad you many need to switch off iCloud private relay in your iCloud settings.
Either of these could be stopping your SIM details from being picked up by My3.
Let me know if either of these suggestions help.
on 12-11-2022 06:37 PM
Hi, 3Broadband.
To set up a My3 account for Home Broadband, connect your device such as a laptop or computer to the Wi-Fi, then head over to the My3 Registration page. Once there, pop in your details and follow the steps on the page.
Once you're done you'll be up and running, and you'll be able to log in easier in future too.
