on 25-05-2022 10:24 PM
Any tips and suggestions to improve bb speed
on 08-02-2024 01:10 PM
To get the fastest possible speed you need to change APN to 1.1.1.1
these settings can only be changed when you switch off the Router, from inside the broadband Router just click the turn off option from with in Router, then switch them back on after you have made the change from with in the Router, then logout of the Router. That will give you the fastest possible speeds.
if you need to know anything about 1.1.1.1 just type it into a search engine
02-06-2022 04:42 PM - edited 02-06-2022 04:43 PM
Hey @Sawkat Great question that I'm sure many others would like to know too 🙌
Where your broadband hub is located can make a massive difference to your connection!
For best signal, we recommend sitting your hub as close to a window as possible, ideally on the windowsill. The following page on our website gives an explanation as to why this is! Where should I place my hub | Three Broadband
Hope this helps.
SarahC
on 26-05-2022 08:20 AM
Need more information. What speed are you paying for? Are we talking hard wired or wifi? Is the problem slow wifi in certain parts of the house?
