EDIflyer
632 REPLIES 632
AkiTaiyo
Debugging call?? Does that mean some progress is being made.. or at least the issue is being looked into?
Nameless
Established
Let us all hope so
I will not place any bets on it but I am at least hopeful
bytespider
Yes I was contacted and volunteered but because I also work when the call was scheduled I was second preference. I really hope something good comes of it.
bytespider
I'm curious, who it was that assisted Three with the tracing and debugging call today? Was there anything other users could also replicate (commands, URLs to visit, etc) that would also help as I think more data from different parts of the country would also help.
toaster
I was on the call with Three yesterday. They did a live trace of my connection while I connected to sites that work and don't work. (I used https://royalmail.com as the main failing one that doesn't work as I get failures about 30% of the time).
They said they had captured all the data they needed. They said they would go away to analyse it and once that was done they would come back to us with the results.
I didn't get a timeframe for when that would be, but I hope we'll hear something this week. I'm seeing this problem across multiple sites so I really hope they are able to resolve it, otherwise I'll have to start looking elsewhere.
I've still been running a script to check the top 100 sites plus a few mentioned on this thread. I have had this issue over the last 48hrs with the following:
  • royalmail.com
  • duckduckgo.com
  • gmpg.com
  • ghcr.io
  • gitlab.com
  • wordpress.org
  • amazon.com
  • t.me
  • s3.amazonaws.com
  • web.archive.org
  • <my test site: hosted AWS>
  • microsoft.com
  • aws.amazon.com
  • s.w.org
  • mozilla.org
  • imdb.com
  • ted.com
  • oracle.com
(This isn't exhaustive as I've also seen issues with other sites while I'm browsing around)
bytespider
Okay hopefully that helps. I assume you're using their DNS, otherwise it's somewhat concerning they can see the sites you are visiting that easily
Nameless
Established
Three does not allow you to use your own DNS provider as far as I can tell but VPNs and WARP do allow you to use a different DNS provider
EDIflyer
Thanks for doing that @toaster - I was offered, however I was unable to do so due to being work.
Midnight54
Established
Curious do you guys get this when trying to launch the xbox app?  At first I thought it was my gaming pc, being first time tried to use it in eons.  It was broke a while ago but couldnt be bothered to look at it.  This loops in circles over and over when try again.  At first I thought it was my PC, but realised my kids pcs are doing exactly the same too - and not a single game on gamepass has worked for them etc in some time.....so I'm wondering if its similar to file downloads in chrome where it just wants to restart over and over (nb:  tried all the usual registry and powershell fixes and MS store fixes.  Not too bothered as dont fancy playing any MS gamepass games for the past few months and dont fancy the mammoth task of wiping my games PC - but if its linked I can see that being a huge problem for some
followed by
I may later try and tether my pc to my work phone which is vodafone to see, out of curiosity - however its trickle speed signal in this house
bytespider
are you trying to log in? unfortunately I can't see the screenshots. if so then yes I've experienced the same and have to retry and retry before I can sign in to Xbox. as such we moved to steam for a lot of games
