on 06-02-2024 04:21 PM
hi, having an odd issue.
Within about an hour of running my internet connection completely drops with any connected device being unable to use the internet, however the router claims to still have a fine connection. some time later the router then claims to have no internet. This is fixed by restarting the router only for the same problem to happen again soon after. originally I thought this would be a router issue so I requested a new one however there is still the same issue.
only possible issue i can see is that the firmware on this router may be old (V1.00(ACIR.0)b5) but i cant seem to find what the firmware should actually be so i'm not sure
Any help would be appreciated
on 13-07-2024 10:48 PM
Also same issue. Has anyone had any luck? It's a shame because when it works, I get 500-700mbps download. But when it doesn't work, my smart thermostat and hot water system runs off a bridge plugged into the router so I wake up with no hot water.
on 20-05-2024 02:51 PM
Exactly same issue for me. This is known and yet their support refuses to acknowledge and says other software must be responsible. Terrible service
on 09-02-2024 02:41 PM
Have the exact same issue on mine too - Constantly frustrating
on 07-02-2024 10:48 AM
Hi @fifofolo,
The firmware for your router should usually update overnight or when rebooted. If this doesn't seem to be kicking in then the tech team should have a system to remotely update you, and can help check if it seems to be an issue with coverage, the local network. If you either start a chat, or call the Broadband team they should be able to help with this.
on 11-02-2024 10:26 AM
Dear Jonathan,
I contacted the level 2 support and they sent me a new sim card, which does seem to have updates the firmware (its now V1.00(ACIR.0)C0) but the same issue is still persisting and I'm not sure what to do. Whenever i call they just check the coverage in the are (its always fine) then replace something.
Is there any other courses of action i can take?
Jack
