on 03-14-2023 11:21 PM - last edited on 03-20-2023 11:47 AM by JonathanB
I received my 5g hub this morning, inserted sim as per guidance at 8am. Its now almost 23.30 and I've still got a flashing blue signal icon and red Internet symbol
Can anyone help please? Rang customer services but they just advised wait a few days and if still the same ring back. I need it for work tomorrow morning
on 03-15-2023 08:11 AM
My best advice, return it. Three has been useless with their connection
on 03-15-2023 10:53 AM
Don't wait a few days lol...
It sounds like either a sim or sim activation issue which they should be able to check/resolve unless its an issue with the sim slot or something on the router itself.
I'd give them another call and be a little more persistent 😉
on 03-17-2023 10:47 PM
Did it eventually work for you?
I am facing the same issue: I contacted them through chat, they said they would connect me to the specialized support, and after that they tell that don't have specialized support via chat and that I would need to call them 🤷♂️
Anyhow, they tell me that I just will need to wait two hours. Next morning still doesn't work, so I call them. After being put on hold, redirected to another specialist and a 45 minutes call, it turns they had to activate the sim card and said it would take another 24/48h. How is that even possible that the sim required to be activated and they don't say anything in the instructions?
on 03-20-2023 12:04 PM
Did you manage to get connected in the end?
Usually SIMs should automatically activate on the morning of delivery, or shortly after a Three store processes the sale. I wouldn't normally expect a SIM activation to take more than 4 hours, so there may have been an error setting up the new accounts.
To rule out faulty hardware, and confirm the issue is with the SIM, I'd try the router SIM in a Three/unlocked phone, if one is available.
Let me know if you're still running into these issues, and if so I'll direct you to more help.
We'd like to hear your feedback! Let us know how easy you find it to get ready to Roam, and be in with a chance to win 7 days of free Roaming Passes – find out more here!
