06-10-2024 09:12 PM - edited 06-10-2024 09:18 PM
Hi there, I have a problem when I working on my code.
When I connect to Three home broadband wifi, and run "docker build" command
30.66 lient.go:12:2: github.com/golang-jwt/jwt/[email protected]: Get "https://proxy.golang.org/github.com/golang-jwt/jwt/v5/@v/v5.2.1.zip": net/http: TLS handshake timeout
The request time out.
Also When I run kubectl command, it gets the error below.
error validating data: failed to download openapi: Get "https://34.88.39.12/openapi/v2?timeout=32s": dial tcp 34.88.39.12:443: i/o timeout;
I've tried those with my mobile hotspot but it works. This only happens with Three home broadband ( I'm using NR5103E)
I tried to change the firewall level but it didn't resolved this issue, so what should i change on the setting?
on 07-10-2024 07:27 PM
Hello there.
It's good to hear that the support team were able to get that sorted out for you.
on 07-10-2024 01:44 PM
This has been solved by chatting with 3rd line technical support, they changed IPV setting and resetted my device.
