on 29-05-2025 08:08 PM
I've bought a new tablet but when I try to connect with the hub it says ' saved/check password and try again '
on 30-05-2025 08:49 AM
Reset your router to factory settings. You’ll then use the default password as printed on there to connect your devices. You can always change it later. The button to reset is recessed and you’ll reed to use a small screwdriver or pin to press it for up to thirty seconds. This is highly likely to solve your problems.
