on 30-05-2025 05:09 PM
Hi All
We've had a Three 3g/4g router (B535-232) for many years, it has 2 rabbit ear antenna and sits in a window on our narrowboat. We can get a signal in most places we travel between Leighton Buzzard and Northampton.
Comparing the router to my iPhone 16 in the same window:
Router 100 up / 20 down
iPhone 700up / 50 down
We are paying £27.48/mo for the router sim (well out of contract) and I am thinking of changing it for the current offering of £21/mo (rising over 2 years) with the current 5g home hub.
Does anyone know what hardware is currently shipping and what ports does it offer? I think it might be an MC888 https://devicesupport.three.co.uk/guides/device/Three/5GHubMC888AD, in which case it's not possible to add external antenna. Not a deal breaker, just means it would have to be by a window at all times.
Also wondering if I could get the outdoor hub offering instead, would be ideal for a pole mount when not in a high signal spot?
Any thoughts on the best option for a steel narrowboat very welcome 🙂
Thank you
David
on 30-05-2025 06:03 PM
The external hub is probably the best option, it comes with a long reel of cable to connect with the eero internal wifi router. I have mine on a roof mounter aerial pole.
Which option the three site reccomends depends on which post code you put into the coverage checker but I am sure you could upgrade to external hub if it suggests an internal one - internal was not an option in my area.
I don't know what you use as a delivery address with a narrowboat!
I got a better monthly price and good cashback (£93) using TopCashback website.
