on 23-03-2025 09:32 PM
I have the 5g hub which wax meant to be a improvement over the Huawei one, I beg to differ.
The connection started off fast and stable, but the last few months I've been struggling with speed , currently luck to hit 120mb. I have also noted the ethernet drops connection from my lg TV.. I have tried various cables to eliminate that.
Terrible service at the moment, probably time to get proper fibre fitted
on 24-03-2025 10:45 AM
Hello there.
It's disappointing to hear that you're not getting the speeds you had before. It's surprising that the newer hub isn't performing as well as the older one. Do you still have the older one to compare?
