on 06-08-2024 02:50 PM
Hi all.
I cannot get my VPN to work on the 3 broadband. Please can someone help me? It works when hotspotting so I know it has to be the broadband that is stopping the VPN from connecting.
Many thanks
on 07-08-2024 09:41 AM
Hi @Welsh_Ben,
Welcome to the Three Community. I'm sorry to hear that you've been having trouble with your VPN. Depending on your VPN there may be a solution here: FYI : IPv6 Prevented VPN Connection
Some Broadband customers have confirmed that their VPN works reliably if switching to a manual APN profile set up for IPv4 only as described in the thread I've linked.
If this doesn't seem to help, can you let me know a bit more about the issue, for example are you unable to connect whatsoever, or are you experiencing intermittent/random disconnections? Which VPN service are you using?
