on 03-01-2023 03:06 AM
I received a notification from Three asking if I wanted to receive recommended games to my phone. I said yes to this, but i no longer want the services. I can't find how to stop this and it keeps installing games on my phone whenever it chooses to. Can anybody help please
on 17-01-2025 01:15 PM
Hi All, I had the same issue with the game center. Managed to turn it off, but automatically comes back after an update. Frustrating.
Settings -> Apps-> Game manager - > Game service panel - > Stop game sercice - > have two options at this point (Stop service or Log out service) Also don't forget to toggle off activity recommendations please. This one should stop it until you have a new update installed on your phone. Happy days guys. 😊
on 16-08-2024 12:48 PM
Disabling AppCloud works temporarily, however when your phone completes a system update it's forced enabled again (or that's the case for me). It's super frustrating.
on 07-01-2023 07:37 PM
Hey, Fuzzy.
Might it be AppCloud you are referring to? If so, you should be able to stop the downloads by uninstalling or disabling the AppCloud App.
You can do that by heading into the settings on your device, head down to Apps, then have a look in the list for AppCloud. If it's not showing, hit the options button and enable the "Show system apps" option and look again. If you find it, go in and uninstall the app. If it doesn't let you, it should let you disable the app instead.
Hopefully that does the trick.
on 03-01-2023 04:26 AM
Hi call customer services on 333 they should be able to sort out your problem.
