on 05-09-2023 03:48 PM
on 05-09-2023 07:48 PM
Fingers crossed as per your last sentence mate.🤞
on 05-09-2023 07:26 PM
@Anonymous
That's probably a fair assessment. I had to use the app "chat" facility yesterday and it went OK, but I would not like to deal with a complicated question via that medium.
I do feel that Three's retail stores are an underused resource for problem-solving, particularly if you use a store off-peak, say at 9.00am on a wet Monday morning. And if you can catch the attention of one of the moderators on this forum, that tends to be a constructive way forward.
The two big plusses for Three are that the 5G is brilliant when it works and, as you have highlighted, the prices. I just hope that the proposed "merger" with Vodaphone doesn't leave us with the worst of both.
on 05-09-2023 10:45 PM
I should also add that as stated by Avondale above,the mods on here are a great fallback if all else fails. Fair play to them.
