on 19-10-2023 10:25 AM
Hello
My Samsung Flip phone has decided not to fully open and I am unable to use the top screen.
Do I contact Three as this is under contract or Samsung direct please to get repaired as under warranty?
Please can you provide me contact numbers to help assist.
Many Thanks
on 19-10-2023 06:51 PM
Hi @Samantha21,
If you pop into a Three store then the staff will be happy to check if they can arrange a repair for you, or if you contact Samsung or a repair service authorised by Samsung, you could get this covered under warranty.
For Samsung devices, we also have a repair partner that you can arrange a doorstep repair with a mobile technician: https://threerepairs.co.uk/
All options are valid, but you should be aware that you can end up having to pay for a repair if it turns out to be some sort of damage rather than a fault.
19-10-2023 02:20 PM - edited 19-10-2023 02:21 PM
If you bought the phone off of Three then you should contact Three. You're not a customer of Samsung and the responsibility sits with Three not Samsung.
Citizens Advice on buying electronics
Your rights apply
to the seller
When you buy a product,
you have rights, but
these are with the seller
of the item, who may
not necessarily be the
manufacturer of the product.
If there is something wrong
with your item, don’t let the
seller tell you to go to the
manufacturer to deal with it.
It’s the seller’s responsibility
to resolve the problem for
you.
on 19-10-2023 11:06 AM
Contact Samsung for service. Have you heard of google to ascertain their contact number?
on 19-10-2023 11:23 AM
What's the betting that Samsung say contact 3?
