on 19-10-2023 08:49 AM
on 19-10-2023 11:06 AM
Turkey is not a go roam country with 3 so charges apply. Check you have roaming turned on. Check to see if you have enough credit, you will need to ask 3 about this. Check your spending cap as it may be set to zero.
Go to settings and manually select a network, try them all if needs be.
https://www.three.co.uk/Support/Roaming_and_international/Mobile_roaming?content_aid=1214306371749
