on 09-05-2023 07:09 PM
I just downloaded the app and I don't have login details . How do I go about it ?
on 09-05-2023 07:32 PM
If it is your first time using the app you need to register before you can log in. If you have registered on the web then you will have created your password. the other other thing you need will be your phone or broadband number.
