I have been trying to connect my phone in Denmark with no success. I have roaming on.
Teppic
My phone will not connect to local network. I have roaming on. I have swapped from no spend cap to £50. I do not receive the text to confirm this has happened. I do get the rate advice text.
2 REPLIES 2
Hi @Teppic,
What you've tried so far are good things to check.  may also be worth trying toggling airplane/flight mode on and off a couple of times.
You can also check in your settings for network or carrier selection and set this to manual. This should give a list of available networks, and if you try selecting these one by one, you can test if any of these are providing service. If you do this, make sure to set network selection back to automatic when you return to the UK.
Let me know if either of these suggestion help.
Geluk
Maestro
Converse with "3" via CHAT, or send direct message via Social Media😁
