on 14-11-2024 05:58 PM
on 15-11-2024 03:17 PM
Hey @MCat,
Ah, that's not good. Are you using Home Broadband? If so, have you reset the router?
Are you getting an error message, at all? Any extra information would be helpful.
Kate
on 14-11-2024 06:01 PM
It happened the same about a month ago.
on 14-11-2024 08:37 PM
Is it just your telly? Might be a telly issue maybe not
If it's a "firestick" or "dodgy box" then it is definitely not a 3 problem. They can buffer simply because they are dodgy
