on 15-02-2024 01:56 AM
I have a number of Kami / YI Home security cameras at home. There is a Kami app for iPhone and an YI app for iPhone. Both fail to connect to the camera for live viewing. They load to maybe 10% or 35% and then restart loading. It never gets there. It used to work on 3G but on 4G or 5G the app will not load the live camera feed. It gets to 10 or 35% then loops back to retry.
joining wifi or putting another SIM card in (tried O2 and EE) resolves the issues. So it must be something to do with data routing on Three. Maybe a blocked port or something. Also reported to Kami, but it will need Three and Kami to work together to resolve this.
if it can’t be resolved I will have to switch providers to be able to view my cameras. This must be a simple answer but needs a network routing techie to look into it please
thanks. Mike C
on 17-01-2026 01:06 PM
Did anyone find a way to resolve this issue ?
on 15-02-2024 09:39 AM
Change the APN you use this makes a difference this will either show in:
Try "three.co.uk" and "3internet" in the APN field to check if you get differing results. 3internet is intended for Broadband, but I've seen a couple of situations where it worked better for certain types of streaming on phones.
