on 21-05-2025 05:32 PM
Hi...I have just managed to purchase 10 days of data passports and have a couple of questions . Am I right in thinking that the first one will be automatically activated once I enter the country I'm heading to without me having to do anything to my phone ?. Also will the following data passport activate on its own when the first one ends at midnight. All seems very long winded. Thanks. (Sorry...repost. I posted in broadband section by mistake.)
on 22-05-2025 12:56 PM
Yes, and yes.
Just make sure that you've got data roaming switched on in your handset settings. Possibly check with Customer Services that roaming is active on your account too.
Apart from that make sure you adjust your Spend Cap accordingly, and check that your Credit Limit isn't set to £1.
Yes, and yes.
