on 18-01-2024 03:52 PM
My Virgin Media Landline wont connect to my 3 mobile phone just says my mobile is unavailable leave a message. Works perfectly ok with all other mobile networks. Have talked to Virgin Media they say its routing ok but something at the 3 end is blocking it?
on 25-06-2024 08:00 PM
Just get a message on the VM line saying I'm busy. This was with my S10, now have an S24 and still doing the same. My wife had the same on her S22 when with 3, since changing to 02 there has ben no problem. Pretty sure its something at the 3 end of things but honestly cant spend any more time chasing it so will be changing to 02 in the near future.
22-06-2024 01:10 PM - edited 22-06-2024 01:13 PM
@PeteG I think I'm having the same issue. Have deactivated spam call blocking and doesn't resolve it. Any other solutions I can try?
on 25-06-2024 02:09 PM
Hi @LDCACCA,
Just to check are your calls going straight to Three Voicemail from the VM line? E.g you're prompted to leave a message? Is this also on a Samsung phone the same as the OP, and have you been able to test any other phone or Three numbers?
on 26-06-2024 03:30 AM
The VM landlines is ringing out but the target 3 handset doesn't ring. Eventually it goes to voicemail. This is then followed up by a text message from 3 saying I've missed a call.
My handset is a Samsung A52 5G. It's also happening with a TCL device (also on 3).
We've tried other 3, non-3 and landline numbers, and they connect successfully.
on 26-06-2024 03:25 PM
Hey there,
Thanks for providing us with the extra information.
I'm going to drop you a PM with instructions on how to reach out to my colleagues who will be able to get this raised to our Support team for investigation.
Kate
on 26-09-2024 04:21 PM
I am having the same problem as the original post. My VM landline does not come through to my iPhone and just rings out to the voice mail. The same happens when my parent call from their VM landline
on 05-05-2024 01:15 PM
Did you get this sorted as my virginmedia landline won't call my 3 number either. Even tried a different smarty network on 3 & still the same.
on 20-01-2024 07:39 PM
Hello.
The fact that you're getting to the please leave a message part would seem to confirm Virgin Media's suggestion that it's routing OK. Are any other numbers having issues making a call to you successfully? Can you also confirm if you recently ported your phone number?
on 21-01-2024 02:44 PM
Have had the phone 4 years, same number. The problem also occurs when my neighbour phones me from his VM landline.
I have gone through my phone settings several times, all barring is switched off, nothing in the barring list. Have used MMI code/s to ensure 3 at their end aren’t barring the call. Also have cleared the phones cache partition, still no joy! What’s interesting is if I set my phone to Barr all calls when I phone it from the VM landline it say unavailable within a couple of seconds so the VM line must be connecting to the phone and very quickly.
And now the spanner in the works… If I take my sim out of my phone and put it in another, there is no problem, VM landline connects ok. Problem now points to the phone (Samsung s10e) but why just VM landlines or maybe other landlines??
