on 07-29-2022 03:29 PM
on 07-29-2022 03:55 PM
I had the same issue in Toronto. Apparently roaming is no longer free in Canada. You pay £6 per day if you want it. It seems complicated to turn on and pay. Then when it is working - my phone connected to Bell network automatically - but still no joy. After a day of not working I had to manually change to Telus network - that worked! I had to do that each day I paid for network. BTW its 24 hours but UK time - so think about when you need the network time.
on 08-01-2022 10:21 AM
Hey Ninjacat,
I'm sorry to hear that you couldn't get connected when you were on holiday. It'll be hard to see what was causing the issue if you've now returned to the UK, but I can give some general advice for next time.
Hope this helps.
on 03-01-2023 01:24 AM
Hello. I have same problem. I was able to use internet in Hong Kong and suddenly none. Spend cap at 3 times. Ire than necessary for the £5 daily. I have unlimited speech and texts and tons data. Only used 3gb so far and I have been switched off and need to download tickets emails etc ! Three app under maintenance and my time zone means your call centre closed for me. I desperately need to be switched back on. Can you help please Jonathan B. Thanks.
on 03-01-2023 02:32 PM
Hi @Kim1,
I'm sorry to hear that you're also running into these issues. If none of the suggestions on my original reply are helping here then I've sent a link to a help team in reply to your private message.
I appreciate the timezone difference is very significant between the UK and Hong Kong, I've included the GMT opening hours for them in the message in case there's a convenient time to contact them.
To view your private messages click on your avatar image in the top right of any community page, then "Messages".
