Roaming not working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
22-05-2023 03:56 PM - edited 22-05-2023 03:58 PM
Good Afternoon,
been having issues with my roaming, last month I was in Poland it work just fine I am in holiday in France and I can see is connecting to the roaming shows 4G but I cannot connect to the server. I ready restart the phone 6 time, i ready did the network restart like 5 times. I need my phone for GPS.
- Labels:
Roaming
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-08-2024 02:51 PM
Hi @Marquesuk,
It sounds like you've covered all the basics. I'd also suggest to double check your Network/Carrier Selection just to make sure this is on "Automatic", it's unlikely but if this was left on manual connection to Three UK your phone wouldn't try to find a roaming connection.
Most likely roaming or a related service isn't active on your account itself. I'd recommend to get this double checked with customer services, and if they can't directly find the cause they should be able to escalate this to the Tech team.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-07-2024 05:42 PM
I went through the same nightmare when I travelled in Apr/May...hours on the phone with Three and ended up stranded with no data and couldn't even get a taxi. I had to walk 15 miles back to my hotel. Three doesn't seem to comprehend how critical a working phone is when traveling. They kept apologizing which really just infuriated me and I never get angry about anything. BOTTOM LINE: What I on my OWN discovered and fixed was the "SPEND CAP" & "USAGE CAP" needed to be set to "unlimited" because their stupid system still does regular charges, then fixes it on billing. You can adjust your own spend cap, but they have to adjust the usage cap. Then I reset my network and it worked.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-06-2024 03:05 PM
I have the same issue. Currently in Netherlands and stuck to using wifi. No signal to call 3 and no means to talk to an advisor even with wifi. Utter scam. My roaming is turned on on my phone. I have purchased the add on. It says in my account roaming not activated. How the heck do I activate it? They said it would happen automatically and it hasn’t.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-06-2024 03:56 PM
Turk operater added..paid the roaming pass data roaming on. Waste of time as above couldn't use in medical emergency. Can't even ring 3 absolute joke. If your reading this and go abroad change provider. Waste of time and money. But potentially put people at risk for not able to access data.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-06-2024 12:23 PM
Same problem here, we both have three. Works perfectly on Android but not iphone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-05-2024 12:38 AM
Three is the worst network when you go abroad the data never works, I’ve had this issue for years and they just tell you to activate go roaming even when it’s on.
if I was you just get a data eSim for when you travel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-08-2024 04:24 PM
I got the same problem. Bought three data pass and they do not even work. The help team is useless.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 24-04-2024 06:19 PM
I bought 3 go roam EU passes, and they don't even WORK... I'm stranded now with no data abroad in croatia, all the signs in Croatian. Complete nightmare. Sat in a call for 2 hours during my holiday and they tell me they cant solve it for 72 hours, and that wasn't even a certainty either, they MAY fix it within 72 hours. Utterly ridiculous, I'll have to goto a local shop and get a simcard for the rest of the trip. Such a hassle.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 23-05-2023 05:09 PM
Hi @YP19,
I'm sorry to hear you're running into issues with connecting from France.
I'm not completely clear on what you mean by connecting to the server. Is this an issue with data specifically, or are you unable to make and receive calls and texts too?
If it's specifically data that's the issue, then the first thing to double check is that "data roaming" is on in your settings.
You should be able to use the network provider abroad that your phone connects to automatically, but it's also worth trying to connect manually if running into issues. If you look for settings for "Network Selection" or "Carrier selection" and set this to manual instead of automatic, then try connecting to any other available providers in case there is a local issue. If you do this, make sure to set this back to automatic when back in the UK.
Please let me know if any of these suggestions help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-03-2024 06:48 PM
we have the same problem, for the second time, and this time during a medical emergency where communications are vital, or would be if we had any. . I share the frustration of many others about being told to check that data roaming is on, but I suppose it's necessary. my question is whether anyone has ever fixed this and if so how. we've have tech support on via wifi and they have given up.
