on 08-11-2023 05:46 PM
A couple of months ago I transfered my number from ID to Three on a new iPhone 15. Since then I’ve had problems sending normal SMS messages - they just end up saying message sending failed.
weird thing is, the problem is intermittent. For some people sms works fine, for others it fails.
ive tried all the normal Apple suggested stuff to solve it, but its not working. Removing the sim, airplane mode on off, even tried it resetting the phone. Nothing fixes it. iMessage works fine, nothing else does.
Any suggestions?
on 06-02-2026 08:50 PM
on 09-02-2026 09:41 AM
Hello, Ronnie.
It's disappointing to hear you're having issues. If the reset steps I recommended above haven't worked for you, you'd need to reach out to the Support Team directly in order to raise the issue and have it investigated. Fingers crossed they will be able to resolve it like the others.
