on 09-07-2022 10:10 PM
Been a 3 customer for many years here and although I've been informed (by 3) there's a transmitter at Bluebell Hill (1.5 miles away) the signal here is still really poor.
on 11-07-2022 03:34 PM
Hi Paul,
I'm sorry to hear the signal is letting you down. Just to clarify, has this been the case for years, or has the coverage only recently became poor?
Can you let us know a bit more about any difficulties this is causing so we can get you the best advice? For example, is this affecting call quality, or causing calls to disconnect? Or is it more an issue with data disconnecting, or slow speeds?
If you can share the answers to the above, we'll see what we can do to help.
