on 10-08-2024 09:11 AM
Been given a text and now an email allegedly from Three about the offer of a new Moto g mobile as the old 2G network is shutting down is this a genuine offer from Three??
12-08-2024 03:42 PM - edited 12-08-2024 03:42 PM
Thanks @NigelHawk, I've checked into this with some colleagues and that does match with official communications we're sending out. If you were sent that text and email it should direct you to a form on three.co.uk to claim the phone
on 12-08-2024 01:55 PM
mistake it read 3G!
on 12-08-2024 01:54 PM
Thanks copy attached into word document. text and email read the same.
on 19-08-2024 04:13 PM
New mobile phone arrived today. Very pleased indeed. The Moto g 04 is a great device and easy to use.. well done THREE. Very happy as my old mobile was broken and unusable. Many Thanks.
on 20-08-2024 09:42 AM
That's great! Thanks for taking the time to update the community @NigelHawk. Also glad to hear that this cropped up at just the right time to help you out.
on 12-08-2024 05:03 PM
Great news Thanks for double checking.
on 12-08-2024 01:11 PM
Hi @NigelHawk,
Are you able to share the precise wording of the text and/or email you received? And also the email address it was sent from? We've never had a 2G network at Three, it's the 3G network that's being switched off, but if you can share what has been said, and where it's come from, we'll be able to investigate further.
on 10-08-2024 07:43 PM
I received a similar email and am also here to confirm it's legit.
on 11-08-2024 05:11 PM
I will ring the main shop and ask what they know about the offer. I just realised I will need a nano card for the newer mobile phones so can ask about the SIM card at the same time.
