on 27-08-2024 09:38 PM
Hi everyone. I’m having a problem. When some one me, it says user busy. It happens with all the calls.
on 28-08-2024 10:28 AM
Hi @BelalAltaf,
If you can make calls but aren't receiving any calls, it's best to double check you don't have a Do Not Disturb or "Call Screening" setting switched on.
If you can let us know which model of phone you're using we can check if there's any specific instructions we can find for this.
