on 27-08-2024 04:40 PM
I am getting an external 5G modem (i.e. one that is mounted outside, to receive best signal) and want to connect it to the Three 5G hub for use as the router. Is it as simple as plugging the Ethernet cable in to one of the LAN/WAN ports on the Hub, or are there other settings to change on the Hub in order to make it work?
The external modem is POE and can broadcast a wifi signal, but I intend to use the IP passthrough feature to disable that function and use the signal from the Three Hub to connect my devices, as I am doing currently.
I'd be most grateful for your thoughts.
JB
on 19-03-2025 03:30 PM
I received by 5g Outdoor hub today and was using a Deco x50 5g router with deco meshes around the house. I switched teh Deco router from 4g/5g router mode to wireless router mode, connected to the outdoor hub and then switched the hub on. Didn't think it would be that easy but everything is working perfectly 🙂
on 15-03-2025 02:26 AM
sorry to jump on also . i also want to know if the outdoor 5g router can be used and put in bridge mode to my indoor tplink router via ethernet instead of the eero ? . my current setup is three 5g indoor router set as bridge mode to my tp link router
on 19-03-2025 03:31 PM
on 15-03-2025 06:07 PM
It's effectively how the eero is configured. You should be able to do that with your own tplink router instead if you wish. I can't confirm for sure though as it isn't a device I've personally tested. As I mentioned on another post here, it's fairly standardised stuff, and should work unless a manufacturer is doing something out of the ordinary.
on 30-08-2024 08:33 AM
Hi Jonathan. Thank you for your reply. Yes, the Three SIM will be in the external modem.
I have found that there is a 'Cable Modem' mode on the Three Hub, accessed as an option alongside Bridge and Wifi router modes. Selecting this appears to enable one of the LAN ports as a WAN port for the incoming connection from the external modem.
Having read-up on IP passthrough, I understand that I will need to configure the modem to use the router's MAC address so the modem appears as the target for incoming wifi connection. Does this sound right to you?
I'd be grateful for any other guidance you or others can offer.
I will post my findings when the router is set up.
on 31-08-2024 06:03 PM
Hello.
As Jonathan isn't around just now, I thought I'd take a bash at answering this.
What you've described mostly sounds right, however the last part about needing to configure the modem to use the router MAC isn't something I'm aware of as a requirement. With the External device in Passthrough mode, you should be able to hook up the ethernet to the Three Hub, and DHCP should configure the device correctly. Then any devices you connect to the Hub Wifi should run normally after you connect them.
I could be wrong though, as I'm not familiar with the External product you're using, but it's not a process I've ever had to follow my self when setting up a network.
on 28-08-2024 10:22 AM
Hey @JusByf,
To my understanding if the Three router will be acting as Wi-Fi router, and it's the 3rd party external device that will be the modem, it's just the external device that would need set to IP passthrough or bridge mode. We don't supply our routers with this set up in mind though, so my info is limited.
I'm assuming the Three 5G SIM is going to be inserted in the external device?
14-03-2025 09:33 AM - edited 14-03-2025 09:34 AM
Sorry to jump on this post but I'm getting my outdoor hub today.. Is it possible to user another router than the supplied eero? I have a Deco mesh system at present which is hooked up to my Three 5g router and is being used in apn mode. Would it be possible to use one of my Decos as my router? Thank you, David
on 15-03-2025 11:05 AM
Hello there.
That should be fine to do as it's all standard network protocols in use. I can't confirm for sure though as the Deco isn't a device I've tested and I'm not familiar with it's features. You can always try and let the community know, it might be useful info for someone some day.
