PS Portal Connection Problem
winterlake
Hello All,
I am having some trouble connecting to my PS5 via my Playstation Portal. I can use the iPhone Remote Play app on the Three network, so I think I have solved NAT issues and APN issues. However, it breaks when I use my phoone as a hotspot, or a 4/5g dongle router as a hotspot to the portal.
Scenario that works:
PS5 via Port Forwarding / DMZ > Router > Internet > 3Internet APN 4/5G > Remote Play App on iPhone
PS5 via Port Forwarding / DMZ > Router > Internet > 3Internet APN 4/5G > Wireless 4/5g Dongle Router > Remote Play App on iPhone
PS5 via Port Forwarding / DMZ > Router > Internet > Other property Wifi > PS Portal
Scenario that does NOT work:
PS5 via Port Forwarding / DMZ > Router > Internet > 3Internet APN 4/5G > iPhone Personal Hotspot > PS Portal
PS5 via Port Forwarding / DMZ > Router > Internet > 3Internet APN 4/5G > Wireless 4/5g Dongle Router > PS Portal
1 REPLY 1
MoNurk
Did you ever find a fix for this?
I have the exact same issue, can access remote play via the iPhone app, but can’t connect using my Portal when connected to the personal hotspot
