on 04-06-2024 08:17 PM
I’m using third party app to make calls to abroad and I noticed when I’m connected with three mobile data then voip call is not getting connected so either I need to use VPN or I need to use second SIM’s mobile data.
Is this known issue?
on 04-06-2024 09:11 PM
Let us know the results.
on 04-06-2024 09:33 PM
three.co.uk 419mbps
3internet 389mbps
regarding VOIP I’ll check and update later
on 04-06-2024 08:33 PM
That’s sounds interesting!
I’ll give it a go.
Have you tested Speedtest results on both APNs and which one is faster?
on 04-06-2024 08:35 PM
No I haven’t checked that. I have an ip camera at home to watch my dog and have to use 3internet to connect to it as three.co.uk doesn’t work.
on 04-06-2024 08:31 PM
Try "three.co.uk" and "3internet" in the APN field in settings to check if you get differing results. 3internet is intended for Broadband, but I've seen a couple of situations where it worked better for certain types of applications on phones.
