on 16-05-2024 12:46 PM
I’ve tried everything can’t hear on calls they can’t hear me. I’ve tried everything and then someone said it’s the network
on 16-05-2024 01:40 PM
If you mean that when you use WiFi calling your phone works ok you’re either in a poor signal area or work is being carried out on the mast your phone is connected to. You can check the Three status page for info.
on 15-11-2024 11:32 AM
I have the same issue, it's the same on WiFi calling and on the phone. I get a pretty good signal at my house and I always have the problem. I use VOIP for work daily and have no problems with that so the latency and bandwidth of my connection should be fine.
