on 24-04-2024 12:41 AM
So as a lone night worker I use the internet quite a lot. Netflix gets a pasting. My works wifi was so poor I decided to invest in mobile broadband and after a bit of research and using the coverage checker, 3 was the best candidate. I had my router and sim yesterday and installed it on my laptop around 2 hours ago. I have a very weak signal and the red light on the hub. The internet is working but at a very slow speed. Any ideas?
on 24-04-2024 07:25 AM
I have an HUAWEI mifi and a red light on that means poor or no signal.
