on 21-07-2024 11:32 AM
Hi I have a ZTE4G router I need to get antenna for it which ones are compatible please. All working ok but cannot get Wi-Fi in the conservatory- advice needed please
on 25-07-2024 03:42 PM
Hi @JLC,
An antenna boosts the 4G reception of the router (although it can often reduce the overall speeds obtained), but it doesn't increase the range of the Wi-Fi from the router.
If I've understood correctly you're getting Wi-Fi in other parts of your property, but the router is too far from the conservatory? If that's the case, I think you're looking for a solution like a Wi-Fi extender, mesh system, or possibly a powerline adapter. These are all viable options, you could look into, but I can't recommend a particular product. I hope this helps you research a solution though.
