on 22-10-2023 03:21 PM
on 19-11-2023 07:06 AM
Same thing.
Error code: PR_END_OF_FILE_ERROR all the time!
I had ZYXEL NR5103E and switched recently to HUAWEI H112-370 (5G CPE PRO) - no change at all, exactly same behaviour, so 100% it's THREE fault. I'm in full 5G signal.
God it's so annoying when it drops the first connection on the browsers. It also does it to my TV EPG so sometimes I have to refresh it few times to get programme list!
on 22-11-2023 04:54 PM
Hey @kris,
Thanks for confirming that this is an issue with the Huawei device too. It seems like it's mainly a 5G issue, some users have found 4G is connecting without this error, with a couple of exceptions, but it seems to vary between different sites. We've gathered some example account details, and I'm passing on any community feedback to help with the investigation though, so hopefully this shouldn't take too much longer to resolve.
on 17-11-2023 01:19 PM
I had switched to using a 4G connection the last 3 weeks after it was mentioned by @Tatablack this does not exhibit the connection issues (although I wouldn't consider it a solution as the speeds are slower) and my experience is that the issue doesn't occur on 4G EXCEPT the last week I have repeatedly experienced the issue when navigating to Wikipedia only. Nothing else just Wikipedia. So the hypothesis that it is only 5G affected doesn't seem wholly true, although on 5G it is many many websites affected whereas 4G I've only experienced this one website affected. I hope it doesn't get any worse on 4G.
on 18-11-2023 07:47 PM
I can confirm. I switched to 4G tonight because I needed my GitHub connections to be reliable (now they are), but indeed I still have problems with Wikipedia or malkoffdevices.com. Puzzling.
on 22-11-2023 04:47 PM
Hi @Tatablack,
Thanks for confirming this. It seems like the issue must be a complex one but hopefully this will help the team unravel it.
on 22-11-2023 05:40 PM
I think it's my fault that the issues around some sites such as malkoffdevices.com are being discussed. I was helped by a user on another forum and turning off the Adult Content Filter resolved all of my permanent connection issues (but not the intermittent ones that are the main subject of this thread), so sorry I think this was a red herring.
on 16-11-2023 06:24 PM
Can anyone who suffers from the intermittent secure connection issues try the following link https://malkoffdevices.com/products/malkoff-hound-dog-super-flashlight - it is just a torch seller in the usa however I reliably get an SSL error when I try to load the page from my Three Broadband, but if I use my BT wired service it loads fine. I'm hoping this is a repeatable example of the problems we are seeing.
on 22-11-2023 04:55 PM
Thanks @BrummyGit, I'm sorry I didn't get a chance to reply but we passed this example over last Friday too.
on 19-11-2023 06:03 PM
That website seemed to work just now for me but have been having similar issues for a couple of months.
Notably online payments and online banking apps are hit or miss. Disney plus, and my5 don’t work but strangely Netflix and prime do.
on 19-11-2023 06:30 PM
Yep I find online payments particularly buggy - just at the time you don't want a transaction to fail!
