EDIflyer
626 REPLIES 626
fashric
Nope, still as bad as ever.
EDIflyer
No change here - still lots of Github errors unless I connect to a VPN.
applepieman
That has clearly been the case since the beginning. Just give us your money and take whatever service we provide. Not long before my contract is up but hopefully this stands as a warning to those looking to use three in future
bytespider
Did any one ever receive a PM from @JonathanB about this issue? Has anyone had any feedback? I'm getting quite sick of this, as a software engineer working from home I tend to pull code from github.com, ghcr.io, and other sites quite often and lately it seems to be getting worse. I set up a script to attempt to pull a docker container until success every 30 min, and it took over 24hrs to eventually establish a connection and pull.
At this point the issue isn't intermittent, my broadband working is intermittent.
bytespider
Another week with absolutely no response from anyone. @JonathanB has been active on other posts so it's my conclusion they are specifically avoiding this one.
wgen
I messaged quite some time ago in January, but haven't had a response. I understand your frustration with this as a software engineer as I'm one myself. I would strongly recommend using a VPN rather than utilising scripts to repeat requests to GitHub to save your sanity. I realise this will cause a hit on throughput, but I think it's worth it for a stable connection. FYI - I'm building images daily.
bytespider
The script was just to prove that the issue is occurring with greater frequency depending on the day and time of day.
I use a VPN when I need to on my work machine, but I dont feel like its a practical solution for other machines like the one running my Home Assistant.
EDIflyer
Totally agree re the HA element, I've got a Pi 4 running that and it's a right pain to try and update things due to the Github connection issues.
@JonathanB any progress?
EDIflyer
Agree, I do the same - I've got a VPN connection to another site with 300Mbps symmetric connection so it thankfully has minimal impact on throughput. Definitely resolves the issue but still a pain to have to do so (and if you forget then you're stuck with timeouts on card transactions, Github, etc.)
baztm
This is still happening to me
As I mentioned previously, I've had two routers, a Huawei and Zyxel and multiple three SIM cards and it has happened with all. The only remedy I have is a VPN but then obviously I take a hit on speed.
I had many months of good service without this happening until at least last year.
