on 02-06-2024 10:36 AM
I'm using a OnePlus 10T and is currently on the latest Oxygen OS 14.0.0.701.
I noticed that one of my apps has been misbehaving especially Instagram. NOTE: i use my phone on an area with very fast 4G & 5G signal when i'm out or at home with my Three's 5G Broadband (ZTE Model No. NR5103E)
I'm concerned because the app doesn't refresh when you swipe it down so I am unable to see new contents. This behaviour is temporarily "fixed" by logging out and logging back it again or closing the app then doing a reset (not factory reset). The problem with this is accumulatively it's using so much time and greatly affect the battery life of my phone.
I'm also blaming the home Wifi because even if i'm living in a 1-bedroom flat and the router placed by the window sill and the line of sight is clear of any obstructions I still feel it could be better.
I don't know if my router needs an update or software optimization or a wifi extender?
Please help.
on 05-06-2024 10:28 PM
Did you try APN change on Three as three.co.uk
3internet
on 05-06-2024 08:20 PM
Will definitely try it and will get back to you guys.
But i noticed something today. Went to work today and connected to our work Wifi.
I noticed that all my apps work perfectly fine including Instagram. When I went home connected to Three's 4G/5G and alternating with my home 5G broadband Instagram fails to load again. This is a phenomenon i'm starting to think that it IS Three's fault and services may need to be looked into especially in my area.
on 05-06-2024 10:26 PM
Has DNS changed something?
on 07-06-2024 08:45 PM
Hi. After installing the 1.1.1.1 app it seemed to have worked.
So far whenever i'm connected to my home 5G broadband or the mobile network I can access Instagram as normal with ease.
But i wanted to ask...why did it took an app in order for Instagram to work?
What did the app do or does?
Will it have any privacy issues?
07-06-2024 10:27 PM - edited 07-06-2024 10:28 PM
Hi it’s cloudflare its a brand in the world of DNS so don’t worry about your Privacy, you can also enable zero trust to double up the privacy and you can also get WARP for lifetime
on 09-06-2024 02:38 PM
If I wanted Warp will I have to pay anything for that?
I already have Google 1. But I heard their VPN service is shutting down.
Also, can I ask if i can install the 1.1.1.1 app on any Android phone even if some apps (or the Wifi) is misbehaving?
on 04-06-2024 08:29 PM
If you don’t have these settings or feel the process is complex then you can download 1.1.1.1 app from play store and install and click on connect and your DNS is changed to CloudFlare
on 05-06-2024 08:24 PM
I have installed the 1.1.1.1 and have enabled the DNS thing. But do i have to enable Warp?
Not mandatory
