on 20-04-2023 04:36 PM
Hi I have recently moved into a flat and I have noticed there is a 5g external antenna installed.
There is only 2 cables that run off this antenna and I know the hub requires 4 so I am wondering if using a splitter for the MiMo would work? Or is it a case of needing a whole different antenna setup for the NR5103E hub?
Jack
on 25-04-2023 04:51 PM
The Nr has two external antennas for 5g the others are internal wifi if I’m correct so two might work, but the internal ones are quite good themselves, if you are close enough
