on 16-07-2023 09:12 AM
Is anybody having connection issues setting up airplay streaming devices through their 5g Hub since the B14 update . It was easy and seamless for nearly a year now it's impossible. Maybe some router settings have been changed. Even a full hub restore to factory settings doesn't help ?
on 19-07-2023 07:17 AM
Thanks I've disabled all IPv6 settings to LAN and firewall . Changed APN to manual as per your solution in a previous thread and its worked .
Finally
on 16-07-2023 06:02 PM
Has the Airplay device been assigned an IPv4 address and listed in the router under Connectivity?
Is the MAC address for the device listed as a static DHCP device in Home Networking?
Maybe the Airplay device needs to be reconfigured again after its been factory reset.
on 16-07-2023 02:48 PM
Hi Ive turned Ipv6 off. My phone and iMac connects on wi fi with no problems.
on 16-07-2023 12:24 PM
Worth checking all your LAN settings again to see none have changed.
Do you know if the router has been assigned IPv6 addresses as well as IPv4 addresses?
Is it only Airplay not connecting or all devices (even your phone) not connecting via Wi-Fi?
