NR5103EV2 poor signal strength
Plymouthpafc
Got 5G blue light, Green WiFi light (good but not never high) but Signal strength on red. Anything I can do about this?
3 REPLIES 3
KateS
Hey @Plymouthpafc,
Are you still experiencing an issue with the signal strength? Or did moving the device around as suggested by @Psmithson resolve this?
If not, I'd recommend checking out our Network Status Checker as this will shed light on any reported issues or work being carried out that could be impacting you.
Let me know how you get on.
Kate
Psmithson
Put it in a different location in the house. Near a window on the correct side of the house (what is "correct" you find by experiment!). I think you can get an external aerial fitted too.
Geluk
Maestro
Put your postcode into 3's network coverage page to see if any local issues.
