2 weeks ago
I used to use ASUS mesh on my copper broadband and it was brilliant as the router was the same brand too and it all worked extremely well....but I sold it (probably a big mistake)
I've a few spare sets of Deco, the M5 and x20, both are a bit outdated but and I've set the whole SSID the same name so AP roaming/connectivity is as seamless as it came be but d/l's via some are only around 50 m/bits
I've tried Deco's X60 and BE9300 with questionable quality so I was wondering what other people are using.
I'm definitely favouring the AP units dotted around the house.
Do I go back to ASUS?
a week ago
Hi @sparkymarcopolo,
Welcome to the Three Community. I can't directly recommend products that Three doesn't supply, but I do know that our Devices team test our Broadband equipment with Eero mesh devices, and we supply them on a couple of our Home Broadband plans.
If you're looking for other customer's personal experiences, there's definitely some other mesh related topics on our forums, if you give them a search hopefully you'll find some helpful info. 🙂
