Work VPN Issues
Sal09
Hi All,
I finally got my replacement hardware today.
Do we have any suggested solutions for Outdoor Y5 regarding VPN Issues?
When I switched on the hub first thing i did was change the APN setting as per many posts on here.
Changed APN name to three.co.uk and set IP to IP (only none IPv6) option available. Inserted the sim and rebooted the device. On first attempt I was able to connect to VPN and then after disconnecting I tried again and no joy.
Changed back to 3internet and that didnt help either.
VPN works fine on EE mobile and Sky BB.
I have arranged a call back from Three tech support. Lets see what they say.
Any help would be appreciated.
Sal
Sal09
OK received another call from Tech Support and they were not helpful at all. Case was referred to the backend team and was advised it will take up to 7 days  for them to get back team. Anyways I did a bit of tinkering and managed to fix the issue myself.
Steps followed as per below:
1. For some reason web browser blocks access to Y5 Hub IP (192.168.0.1) so best way to access your Hub is connect laptop or pc to hub using ethernet cable directly from PPOE box. Follow these instruction https://community.three.co.uk/t5/Devices/5G-Outdoor-Home-Hub-by-Greenpacket-Y5-210MU-Helpful-Informa...
2. Once you've done the above please login as 'admin'. You can find the login details on your Hub.
3. Go to Network Settings and modify the 3internet profile. Change APN name to three.co.uk and IP type to IP. Press OK and then Apply. Wait for few minutes for your Hub to lock in signals again. Once Profile is showing again double check the changes got applied.
4. Restart the Hub (I did it but you can skip it and try the next step)
5. Login again as admin. Now in Network settings you need to the Mode from IP Passthrough to Routing. Press Apply/Submit. Now wait again few minutes for Hub to load everything.
6. Go to Advanced Settings and the Firewall. Under ALG I enabled L2TP Passthrough (as thats what I needed). Apply/Submit.
7. Now disable the Firewall all together. Apply/Submit.
8. Now check your VPN if its working.
9. Go back to Network Settings and change Routing back to IP Passthrough. Apply/Submit. Now wait for few minutes for your Hub to do its thing.
10. Once Hub is fully operational try VPN again and it should work.
11. Now connect the ethernet cable back to EERO. Wait for the light to turn White.
12. Connect to your WIFI network and try VPN again. IT SHOULD WORK.
p.s Make sure Use Default Gateway on Remote Network is ticked in adaptor settings under Networking -> IPv4 -> Properties.
Happy Days.
9 REPLIES 9
Sal09
I changed APN name back to 3internet to test and the VPN works. Im finding 3internet more stable than three.co.uk
Sal09
Happy Days.
jr0
Hey @Sal09
if I'm following what you did was, deactivate the builtin Fw and set operating mode to "IP Passthrough" (no NAT and your laptop/devices gets the public IP instead of the 5G router).
If you really need to do all those steps only means one thing imo, "not so great hardware and/or firmware" by the Outdoor Y5.
But really well done for finding a way through.
Sal09
Outdoor Y5 Hub connects to Eero Router so that where all the routing happens. Outdoor Hub is essentially being used as an antenna.
New Outdoor Y5 hubs are being shipped with buggy firmware where you cannot access their web interface hence I had to connect my laptop directly to Outdoor Hub to make these changes.
After I made the necessary changes I plugged the Outdoor Hub back to Eero Router and setup my Home Network. They did eventually pushed the patched firmware in few days time which is very helpful if you to access the Outdoor Hub to check signal strength etc.
To be honest its a decent hardware, just really very poor support by Three. Support is non existent. They still haven't rung me back lol.
Sal09
Its definitely the hub. Just tried VPN on my iPhone 16 Pro using 5G Home BB  sim and it works.
jr0
What VPN client you using?
Sal09
Windows 11 built in
VPN type: L2TP/IPsec with Pre Shared key.
jr0
Ok, let us know how you get on.
And prepare yourself for Three support... as they say "If you can't cry, laugh"
good luck
Sal09
Already had first interaction with them as I couldn’t wait for call back.
Made me do multiple hard reset both on Eero and on Y5 Hub. Made me change IP range on Eero.
Call ended with suggestion to escalate it to back room team. Gave them the name of ISP for my work.
Still got 6pm call back in place. They might know something lol.
I would really love to keep this service i do not have Full Fibre.
Below is what im getting with Hub indoors.
